Recommend amp for AudioFocus 10" Double magnet woofer..any1 can help me plz.
vs125TURBO
Anyone can help me out there,i gt a 10" Audiofocus double magnet woofer. bt i din know wat amp i shud buy for it, bcoz the woofer din state any output power and ohm.And my budget is around 300-400..( included rca cable, power cable n hi-lo converter) my car is myvi. orig HU
why not go back to ur seller and ask for the specs? 300/400 for an amp is way too tight
they amp was got from my fren, i din know where to buy.and i hv check the similiar woofer on9..then wat i got is..this kind of woofer is 200rms....there i think i shud get at least 200 continuous power amp to pump my woofer
if its 200w rms sub, then just look for a 50wx2 amplifier should be enough, but if more power better la. for your price range try looking for a 2nd hand unit...
bro zenn.. due to frustration about my not stable amp for 2ohm operation today i got myself ONE piece of MTX RT12-44 (dual voice coil,4ohm+4ohm operation)... since you are more xperienced in this field, mind telling me what power rating of amplifier will suit best for this woofer..? im still maintaining my 300w+300w (RMS) amp
this is also 200W rms sub, and u still need an amp that can play 2ohm stable mono, since this is dvc 4 ohm sub.
