is it possible to fit 1.6GB into 4g1X ?
since I think the current GB are close ratio, would it be a good match for high cam since we can drag it longer each shift & better top end & speed ?
jombiee, it can be done. but it will be a hassle for saga/iswara, bcos u need to install clutch pump, and do custom driveshaft. if u use potong sambung driveshaft, it wont be reliable.
thanks khoyos
because I have another 1.5 block for project, so I'm seeking what is the best setup. just a small project. wanna try twin weber, race cam which are plug n play but not really sure about GB & 1.6 rebore either using kembara, 4g91, waja or mivec piston, kembara sure gonna mods a lot, are the other 4G(91/91)series has the same piston pin size ?
woo,everybody looking forward upgrading bigger piston...
but as my experiance 4g13 bore using 4g91 piston is the perfect choice coz juz a minor mods for the piston pin....
I really need your help here..I sent my lexus IS200 for timing belt change recently and my foreman said that my crankshaft timing pulley is already worn out and needs to be changed..He couldn't find it...
i got a quotation of changing my td04 twin fin to td05 16g big twin fin using back the original housing...quoted around RM 1.1k plus totally overhaul the turbo....
