- Joined
- May 26, 2006
- Messages
- 775
- Points
- 1,518
Somebody please sticky this.... :)
The following URL describes how to fully reset an A32/33 ECU.
http://www.brianv.net/mods/ecu/
Something you will have to remember...
The procedure in the URL refers to a LEFT HAND DRIVE vehicle. Hence, the ECU is described as being next to the accelerator pedal and is approached by removing the panel on the driver's side.
WE all drive RIGHT HAND DRIVE vehicles. The ECU is in exactly the same place, but should be approached from the passenger side.
Be careful not to "over-screw". Just us a test pen and turn gently until it stops. Do not force. This screw is not load bearing...hence, there should be no resistance. It simply acts to connect 2 points on the ECU main board...much like jumpers on a PC motherboard.
