my plan was to have an open pod air filter installed and then placing an air scoop right above it for the cool air to go in,.. instead of just leaving it.. becoz if we dont, there will be alot of hot air there.Originally posted by Maxx@Feb 17 2005, 00:38
i've compare tempreature between open pod (on top carb) with the stock (round metal case). temp. in open pod is lower than the stock when cruising.
temp. in open pod abit high when stop/low speed compare to stock.
so, im thinking of diying using aluminium sheet to make cover or "air tunnel" for the open pod for cold intake (filter still on top carb).. will this be a goog idea or better stick to the stock? becoz using open pod feels abit more responsive.
can we use the washing machine pipe to do the cai? or will it melt under the heat??Originally posted by kennethfong@Feb 20 2005, 13:10
windz,
nice work done, ur not kedekut, but u know the way 2 do things at the economical yet efficient way......
Originally posted by Vyraz+Feb 21 2005, 09:16 -->
QUOTE (Vyraz @ Feb 21 2005, 09:16 ) --QuoteBegin-kennethfong
@Feb 20 2005, 13:10
windz,
can we use the washing machine pipe to do the cai? or will it melt under the heat?? [/b][/quote] the washing machince hose is a bit small in the diameter.... try to find a cheaper hose.... i'm using dust hose.... its plastic too.... but it go larger diameter.... my one is 3' :D |
well this is my diy![]()
wifey lenovo wit tapatalk
its not hose its pvc pipe & accessories, bay is to compact for hose that when bent its sort of flattens out blocking the air. found short pipe so tested & its same size as ori intake so thought maybe the accessories can be used, cost me less than 10 for it
. in the 2nd movie they crashed not 1 but two monsters. 1 fd3s and 1 jza80
. what do you guys think? worth or waste?
