nitrous kit
how much it typically cost to refill the nitrous? then can the wet kit do the purge stuff or gotta use the dry kit?
refill the NOS tank is around RM 140-180 depending where you go.
in order to put in a purge kit is roughly the same price as putting in another NOS kit.
because it has to run a different tank all together and normally they use c02.
thought co2 tank purge kit is fake wan..?? i mean only meant for show off here and there ler...
actually can purge from N2O tank wan mar...just the valve thingy + a controller / switch wont cost that much right??? dunno
you need a different setup all together, need a different bottle, lines, solenoid, etc
if it was so easy, i'm sure alot of ppl would do it after fitting nitrous,
but in reality, you need an extra RM 2000++ to purge co2 ! :)
http://forums.evolutionm.net/showthread.php?t=120202
nothign wrong with alcohol hehe, almost the same
hope 1 day can cos fuel really very expensive and in the future dont know will how much.....
sdf from pyt motorsports..
sum-dum-fuck from Pei Yan Tiu Motorsports
i want, thinkinig of using direct port type, but very expensive right??budget 3.5k possible?
try calling Thomas ( 019-6625 384) for more info.
