need help!!!
rockfire
i had change my spring (AMP) but still using my old absorber. when i make a left and right turn, there is sound coming out from my tyre area. it like the spring is loose or what. can u out there help me solve my problem.
thks
mine using koni adjustable...when i start accelerate from 1st gear..there's a knocking sound...and when there a bumpy road..also there a knocking sound at my absorber....go check at my mech...it was the absorber loose and the nuts a not tight enough...mybe u should check the absorber loose or not...also check ur lower and upper arm or ur bushing need a replace....
err... just check is it because of spring adjust not properly with top pillow?
go check wit ur mech.. many reasons of that, spring nor properly install, bushings, top mount, arms, bla.. bla..
i have already go and check with my meachanic. the guy said it is normal to have sound he put a tube into my spring it stop the sound for 2 weeks after that it came out again.isit due to my absorber is origanal so it long abit and the spring is aftermarket short abit.
Normally when u put in tube it will close of the sound...
2 weeks??? u always fly your car???
mine use already 1 year and now absorber kong liao the tube still in good condition...hehe..
the sound comes out when u turn left or right.. driveshaft maybe..
