need help for TyT vellfire
gunnerzz
Jul 3, 2014
2,109
695
Melaka
Its weird coz the abs and check engine light came on at the same time.
Did u drive through standing water at high speed or go through deep water?
If yes then could be just a wet sensor or connection.
Bad alternator and weak battery oso can contribute to warning light but most of the time it will be intermittent.
dont worry too much abt the abs light as u still have normal braking functioning as usual.
Is that ABS or traction control?
Long distance driving and suddenly the light turned on? Were you speeding a lot? Perhaps you have a overheated gearbox. Just stop for a 10-15 minutes let the car cooldown and try again
ken yeang
6,617
1,327
I think its traction control.
Anyway, the cheap effective way to prevent sensors from tercabut is use some zip-ties. Just have to make sure they are not exposed to hi heat.
hi guys, I'm restoring/modding a fiat 600D at the moment, shell is having a full rebuild with factory panels where possible and hand made repairs in other areas, the shell is almost done, and now the decision is to with fiat 903 with abarth tuning parts (ready to fit in my workshop) or change direction and go daihatsu L2 or L5. Here are a few pictures of the shell build up, at the moment I have it as a rolling shell to set up the Abarth wheels arch kit and the front fender cuts, after this...
