need help for TyT vellfire
My meter suddenly pump up this 3 light!is it any problems with my car!I'm driving from kl to Johor but when reach melaka it become like this!please help
does your mpv feel sluggish? any side effects? trying restart the engine?
yeah need to plug in MUT scan to diagnose the issue. could be a faulty or dirty sensor.
Its weird coz the abs and check engine light came on at the same time.
Did u drive through standing water at high speed or go through deep water?
If yes then could be just a wet sensor or connection.
Bad alternator and weak battery oso can contribute to warning light but most of the time it will be intermittent.
dont worry too much abt the abs light as u still have normal braking functioning as usual.
Is that ABS or traction control?
Long distance driving and suddenly the light turned on? Were you speeding a lot? Perhaps you have a overheated gearbox. Just stop for a 10-15 minutes let the car cooldown and try again
I think its traction control.
Anyway, the cheap effective way to prevent sensors from tercabut is use some zip-ties. Just have to make sure they are not exposed to hi heat.
