Advantages:
-makes ur Tire look bigger..covers the wheel arch
-the ride would be comfortable..
Disadvantage..:
--the handling would suffer but u may not notice it..
The lower aspect ratio responds to lateral force more effectively than a tyre with a higher aspect ratio. The aspect ratio affects steering stability. Generally, the shorter the sidewall, or the lower the aspect ratio, the less time it takes to transmit the steering input from the wheel to the tread. The result is quicker steering response.
http://www.yokohama.co.nz/Assets/flex_graphic.gif
Aspect ratio also affects the tread contact patch. As a rule, a low profile tyre produces a wider tread contact patch. This wider tread contact patch creates a stiffer footprint that reduces distortion and provides improved cornering traction. Aspect ratio also impacts ride. A low profile tyre usually has a stiffer ride than the standard aspect ratio of 75 or more.
