What is the correct pressure for 195/50/15 tires? I would usually pump 200, but I notice that my tires are flat, tires eat one side already. Sigh ..
if still happening, try to fill with hidrogen air...can get it in certain tyre shop...RM5 per piecesimplythebest said:What is the correct pressure for 195/50/15 tires? I would usually pump 200, but I notice that my tires are flat, tires eat one side already. Sigh ..
normally if one side being worn...is ur allignment correct? check ur camber setting...r u using pillowball?...maybe u can go yskhong...they do superb allignment there...and u can ask more on tyre pressure coz they hav a rally team...simplythebest said:What is the correct pressure for 195/50/15 tires? I would usually pump 200, but I notice that my tires are flat, tires eat one side already. Sigh ..
Just wondering how much does an alignment, cambering work cost at YS Khong...anybody knows?mahfudz_mn said:normally if one side being worn...is ur allignment correct? check ur camber setting...r u using pillowball?...maybe u can go yskhong...they do superb allignment there...and u can ask more on tyre pressure coz they hav a rally team...
Could also be the alignment, but I just don't like seeing all my tires flat. I don't have chamber screws, didn't fix.mahfudz_mn said:normally if one side being worn...is ur allignment correct? check ur camber setting...r u using pillowball?...maybe u can go yskhong...they do superb allignment there...and u can ask more on tyre pressure coz they hav a rally team...
totally agree!!! coz tyre pressure is one of the important dependence when it comes to thread wear...normally once in a while i'll go to workshop so they fill in n measure the pressure using a gauge...reccomended...coz to buy a reliable gauge cost bout 40 bucks...those cheap 5 bucks wont doWill78 said:In my experience, some petrol stations have faulty air pump meters with inaccurate reading. So, you may think you pumped in 32psi, when in actuality you might only be getting 28psi.
It is recommended to invest in a reliable air pressure gauge.
