- Joined
- Nov 21, 2008
- Messages
- 12
- Points
- 1,501
Hi Guys,
Need your opinion on solving the problem, currently running with 4AFE engine, the problem occurs when you are in low rev and its start to jerk badly all the way. Check the plug cable, plugs , injector and the compression its all ok. The best part is once the mechanic open the distributor cap, there's lots of pieces of solenoid wire there. its shows sign like the solenoid is deteriorate due to age. When the mechanic clean with the air gun , start the engine and the jerking is no more. I need to clean the distributor cap once the jerking happens once a week with the reminder from the mechanic to change the distributor or else it wont start any more.
I have the option to change the distributor, but before that juz would like to have some opinion and some question:
a) is it the distributor can be service and change the solenoid , if can, any contact and the cost.(used distributor ,cut shop, cost me RM 270 w/out installation.
b) Beside the above listed problems due to jerking , are there any that I miss out.
Thanks
Thanks
