Obviously you never driving 6a10 on a wira right? I drove one but on satria. So smooth, the power is there when you need it.Not great power but enough power for normal driver.I still dont understand why its wasted to put a V6 on wira? maybe your interest is in Power riding, not smooth riding.And people should know their car limit,as how hard they can trash their car,whats the advantage their car got.And at kerinchi link, evo 9 oso turtle maa!
btw, how about this :
6A10
With the engine capacity of only 1.6 L (1597 cc), this is the smallest yet most powerful 1.6 L engine available on production car. With the configuration of 6 cylinders, http://www.absoluteastronomy.com/reference/double_overhead_cam (dual overhead cam: a double overhead cam (also called a dual overhead cam, dohc, or "twincam") engine...
[follow hyperlink for more...]) (DOHC), and http://www.absoluteastronomy.com/reference/multi-valve (4 valves per cylinder: in automotive engineering, an engine is referred to as multi-valve (or multivalve)...
[follow hyperlink for more...]) , the 6A10 engine manages to output 140 hp (104 kW) @ 7000 rpm in stock condition.
Available in the http://www.absoluteastronomy.com/reference/mitsubishi_lancer (Mitsubishi Lancer: the mitsubishi lancer is a compact automobile built by mitsubishi motors corporation....
[follow hyperlink for more...]) MX in 1992, this engine was once the most sought after engine for modification in Japan. In 1994, the Kotsumi's brothers from Kanagawa, Japan, managed to turn the 1.6 litre engine into a 'little monster' able to produce 430 bhp (320 kW) @ 6000 rpm without a forced induction system.
source : http://www.absoluteastronomy.com/reference/mitsubishi_6a1x_engine1
dimensions & weights Wheelbase 2500 mm 98.4 in Track front 1450 mm 57.1 in
rear 1460 mm 57.5 in
Length 4270 mm 168.1 in
Width 1690 mm 66.5 in
Height 1385 mm 54.5 in
Length:wheelbase ratio 1.71
Ground clearance 150 mm 5.9 in
Kerb weight 1060 kg 2337 lb
Weight distribution
(Front)
Fuel capacity 50
litres 11
UK Gal 13.2
US Gal
Lancer MX spec : http://www.carfolio.com/specifications/models/id/?id=131494
Ground clearance 135 mm 5.3 in
Kerb weight 1080 kg 2381 lb
Weight distribution
(Front)
Fuel capacity 50
litres 11
UK Gal 13.2
US Gal Wira 1.5 Spec : http://www.carfolio.com/specifications/models/car/?car=124223&Proton
seems like wira 1.5 heavier than lancermx 6a10. So...but of course, if this information is wrong then dont flame me! :P still learning maa...ima kid only.
