Recently i've read up some articles, found out a good IC SHOULD not only lower down the temp but also to improve flow which shld be the factor if we ever wanna change it.
However the articles also did some dyno test with a few various IC, Ebay IC, thier own local country made IC and branded one. I was suprise to know that in majority of the IC does lowered the intake temp however the flow rate drop which result lower hp rating. The articles did mentioned lowering the air temp is important as its to prevent detonation which result enable higher boost but also at the same time the flow should not be neglect out which majority does.
SO what are the key element in choosing the IC? Bar, Plate, Fin? With more and more local intercooler manufacture is popping out, what do you guys think of those IC quality?
Having used Evo7 IC selling around RM900 onwards, its very contracting with some aftermarket performance IC for an example Apexi Hybrid IC which can be get around RM700 onwards as well. But which would you preffered?
help
