kelisa engine....
sunnyboy
439
Can anyone tell me. Kelisa engine can put in to kancil 850EX or not..?
syah
236
sure can...
but have to mod. the mounting laa..
to me,, i prefer kelisa engine compare then L2..
1.0 twincam, injection..
less problem
kelisa6009
17,144
40
Penang Kia
sure can...no problem wan...u can search for this forumer k-kid in kelisa gathering
slk850
885
JPJ will approve ? :confused:
malice
278
www.keiconcept.net
huakenny said:
jpj should be no problem coz from same category car (daihatsu)
you are wrong indeed... for instance if a toyota vios put in supra's 2jz inside coz its same category mah..?????
as long the conversion do not exceed 25% of its original displacement it should be fine. About changing mounting im not sure. Btw kelisa and kancil sharing the same mounting or different mounting?
johnson_goh86
428
diff mounting.. but minimal differences ler.. can be done ler.. i think jpj will approve.. not much diff in displacement wert...
huakenny
LB Performance
9,126
240
Kota Kinabalu
all car after changed engine need to go to inspection st puspakom......not problem then jpj will approved.....jpj wil aprroved engine from same categry wit 25% +/- of d current engine cc.....
that only applied to japanese cars...if urs is europe car..then u can put in japanese car engine......example....mercedes with supra engine..it is approved by jpj.
syah
236
alien said:
I thought when changing mountings are involved, it wont be approved..?
correct me if im wrong...
u r rite,, if change mounting, JPJ will not approved...but if u have money.. should be no problem..
u can ask runner to do it for u:)
kelisa6009
17,144
40
Penang Kia
i agreee..if u got money...anything also can...$$$ play an important rules...:p
Hi Folks,
After 2 years of running my E46ci with unoptimized 1JZGTE VVTI, i picked up an Edamage Blue which i had for several years to hook it up. As expected, used ECU always had problems, my ignition harness is not readable but the rest of it works fine. Initial runs started with 235 whp/ 315nm wtq at 5.2k RPM. A few more runs and we achieved 251 whp / 320 nm wtq at 5.1k RPM. I am not sure whether this is a healthy result of 1JZGTE VVTI, considering factory declared crank HP is at 276hp...
