kelisa engine....
sunnyboy
Can anyone tell me. Kelisa engine can put in to kancil 850EX or not..?
sure can...
but have to mod. the mounting laa..
to me,, i prefer kelisa engine compare then L2..
1.0 twincam, injection..
less problem
huakenny said:
jpj should be no problem coz from same category car (daihatsu)
you are wrong indeed... for instance if a toyota vios put in supra's 2jz inside coz its same category mah..?????
as long the conversion do not exceed 25% of its original displacement it should be fine. About changing mounting im not sure. Btw kelisa and kancil sharing the same mounting or different mounting?
diff mounting.. but minimal differences ler.. can be done ler.. i think jpj will approve.. not much diff in displacement wert...
I thought when changing mountings are involved, it wont be approved..?
correct me if im wrong...
all car after changed engine need to go to inspection st puspakom......not problem then jpj will approved.....jpj wil aprroved engine from same categry wit 25% +/- of d current engine cc.....
that only applied to japanese cars...if urs is europe car..then u can put in japanese car engine......example....mercedes with supra engine..it is approved by jpj.
u r rite,, if change mounting, JPJ will not approved...but if u have money.. should be no problem..
u can ask runner to do it for u:)
i agreee..if u got money...anything also can...$$$ play an important rules...:p
Write your reply...
