Hi Guys,
I'm driving 4 years old 1.5 Wira and I keep losing my engine oils these days. It had become more apparent days by days. At first, i'm suspecting it was Mobil Semi-Synt was too thin to handle it as I am travelling once a month from KL-PG and sometimes on spirited drive (redline :rolleyes: ). The rate of Mobil S oil losing is still bearable.
Since I thought it was Mobil S, then I changed to Petronas 15W-50 which more thicker than previous one. Shit, this is more worse, the engine oil dipped to minimum level after 2 weeks of changing. In this 2 weeks time, as usual, I had done outstation travel and again, some spirited drive. This kind of situation is really puzzling me.
FYI, I'm still haven't consulted any mechanic. But I'm quite sure they all will say your valve head or piston rings are not doing their job well and need to change. This is not good (at least to me) since they are not doing extra testing to confirm that.
So guys, what is your inputs on this matter? What or how the mechanic will do before they really can confirm the valve head or piston rings kong?
Hope you guys can help me out here! B)
Thanks.
KCi
Thanks.
KCi
