How far can we skim the BT20V original flywheel?
use aftermarket one lor... more safety... don't skim except u really know m/shop done balancing. hehehe...
They should skim and balance in 1 package ma.
---------- Post added at 10:36 AM ---------- 6 hour anti-bump limit - Previous post was at 10:34 AM ----------
who said x pecah... On my previous project, I do make the stock flywheel up to 4.0 kg only... within 2-3 month, the flywheel pecah inside, and the bigger thing is gearbox housing was crack too... So better don't take risk and buy a lighten racing flywheel.
u skimmed exceed the limit that why pecah maaa...anyway i also use after market, os giken....hehe
Yes flywheel only... 8.5 inch... condition superb and like new. For you information the pro of using Exerdy & TRD, is if later on found un-even surface, it later can be skim to make it even. The material is billet. TODA, Big Corner, toms, OS & and majority lightweight flywheel are material by aluminum 1 and if found un-even it was unable to skim already.
4.3 kg only.
Bro TRD,
I got enquire from Exedy, they told me the Exedy flywheel is at 4.92kg. As you mention is 4.3kg only, is it being skim before :confused:
---------- Post added at 01:04 AM ---------- 6 hour anti-bump limit - Previous post was at 12:59 AM ----------
3.3k, whole set. I have a few options on used ones but i choose to get a new pack due to some certain personal reasons.
Crank up - Samurai Sword
Press Clutch - Bearing spoil sound
No regret paying for this non performance improvement part. :driver:
This statement is from Exedy...
Extreme lightweight flywheel could affect uphill & top end performance, therefore EXEDY Lightweight Racing Flywheel is slightly heavier than most aluminium type. It weight at 4.92kg, approximately 35% lighter than stock, providing better engine respond without sacrificing low speed torque.
Bro km_chew,
What is the weight of your Ogura flywheel? Do you experience bad uphill & top end performance as mention above? Or any bro that skim the original flywheel will have this problem?
Again, as an owner of this ORC for my car, i would say this is a racing clutch which is usable on the street or track. As for the flywheel weight, does it really matter? Why everyone so sensitive on the weight? Heavy / light weight, it depends on your engine and set up you wish to use it with. (earlier on my post, I've mention that I didn't weigh it)
Check on the receipt, price is Another to add on for this ORC. The replacement kit are as hefty as the price tag which for my personal opinion, if you buy it, means you must be ready to pay for the replacement price without complaining later on.
PM me if you want the detail, where to buy it from.
Thanks for the info bro :biggrin:
