[WTS]Used EXEDY lighten Flywheel for EVO
koie587
selling EXEDY lighten flywheel...brand new cost AU$550 for the flywheel only...
item come with 30% exedy clutch plate and exedy clutch cover...
by using this flywheel ur engine response will be much greater...selling it RM750nego...
the flywheel need to be skimmed b4 installing it to ur car...
if interest u can sms/call me at 012-2595323...
http://www.mudah.my/Used-Exedy-Clutch-set-for-EVO-4297159.htm
Google Image Result for http://www.meek.com.au/images/uploads/thumbs/thumb_Exedy_flywheel_7_bolt_EVO1-3.jpg
EXEDY Racing Flywheels are made from solid one piece billet chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance air flow to improve the cooling of the clutch. The ring gear teeth are milled onto the flywheel unlike an aluminum flywheel where the ring gear is pressed onto the flywheel and have the possibility of separating from the flywheel
thanks for the free bump...........:biggrin:
