Help with ABS light
chipstar
kl
Hi all.I just installed a cheap 2 way alarm at nearby acc shop.first time went there,after finished the installation there was no problem.later went there 2nd time to fix relay for trunk release and after that my ABS light came on(it stays on after engine start and wont go away with ecu reset).the installer said to solve it is to find shop with diagnostic gadget.anyone faced this b4?how to overcome this problem?
You can call william from trial tuning at this no 012-2139861 , he has the so call diagnostic gadget :)
thanks for feedback.maybe ill go search for this place trial cause ive never been there before.seems like its a highly reputable place for msian altezza owners.any guide how to get there from gombak?
yup..be prepared to pay for the tools...even if it doesnt conclude your problems..
to get to trial, better get on jalan tun razak, southbound.
somwhere near the sg besi air base, get on the BESRAYA highway..
you'll pass several exits namely chan sow lin, salak selatan, kajang...
but get off at kuchai lama exit...(if u passed the tol already, then you have missed it)
at this exit, turn right under the under pass...
go straight...then at traffic light turn left...
go straight a bit and you will see trial on the left...with lot of Motul signages..
hope this helps..
Hi Chipstar,
This usually happens when inexperienced acc. shp workers screw up the wires especially along the door panels and below the HU panel.Apparently the ABS sensors are quite sensitive.
It shouldnt be a big deal to re-set it at any shop that has a ECU diagnosis box.
thanks guys for the replies.ill be going to trial tomorrow afternoon.i regret to install at first place.but no choice since budget so low.i hope it gets solved soon.
Hi Chipstar,
Tell me about it!!! Had my share of inexperieced Acc Shop!!!....
By the way, nice signature...a pic of your car?...:rock:
Write your reply...
