- Joined
- Apr 26, 2004
- Messages
- 803
- Points
- 5,018
Satria_95, no difference.
However, it is a good practice to put in Tufoil first. Sometimes when you fill the engine with the new motor oil there is a chance that you overfill and exceed the max mark on the dip stick. And then there is no vacancy for Tufoil.
Always check the dip stick level after a short warm up at the service centre. If the oil level is over the maximum, it is very important to drain off some. You can take this action at the workshop there and then. They will use an oil extractor or loosen the sump nut.
Semi-syn combination with Tufoil is already very good if budget doesn't allow.
:slug::slug:
