i have a problem with my engine. bad idle. check engine light blinking shows code 4 2. refer to the gti diagnostic chart, it means crank angle sensor. what should i do. anybody can help me?
problem fixed. found no.1 spark plug melt. i replace the spark plug and the check engine light clear. it happened when in a hi rev. i don't know why the spark plug melt. it happened to me 2 times. only no.1 spark plug :hmmmm:
If I'm correct, your head gasket should be faulty this moment ...... You can try to send your car to workshop and have engine compression check see all 4 cylinders have the same compression reading.
out of curiosity, how many out there (in Klang Valley / Malaysia) owns an olskool Z S30 (240z-260z-280z) and S130 (280zx) ... ZTH member would be better
Discription
Claimed the best flowing headers on the market, this has been through the "EXPREME" service channels,
*CAD DESIGNED
*ENDLESS BENCH TESTS
*2 Years of R&D
*Lite weight...
