i have a problem with my engine. bad idle. check engine light blinking shows code 4 2. refer to the gti diagnostic chart, it means crank angle sensor. what should i do. anybody can help me?
problem fixed. found no.1 spark plug melt. i replace the spark plug and the check engine light clear. it happened when in a hi rev. i don't know why the spark plug melt. it happened to me 2 times. only no.1 spark plug :hmmmm:
If I'm correct, your head gasket should be faulty this moment ...... You can try to send your car to workshop and have engine compression check see all 4 cylinders have the same compression reading.
Hey all, have 2 design samples that i have done, please take note that all design are works in progress and can still be edited. Would appreciate if any of you could give your ideas,advise(bad or good) or any...
