Finally.....
Finally, i have solved the problem without the help from
service center in proton as they still refused to fix my car with the reason, "Deeparaya lar,
manyak kerata mau bikin. Airbag manyak susah dan bikin airbag ambil manyak masa. Lepas, deeparaya lu datang ar, masa tu mungkin boleh bikin. Atau lu tinggal kereta 2-3 hari sikalang, boleh cuba bikin sama lu ar".
Initially, i thought was some loose cable underneath my steering that cause the light, but after tightening it, the blinking light eventuatlly came back.
As i was rejected by proton service center several time, i was fed up with the sickening blinking and eventually send my car to a nearby workshop.
The technician eventually removed the whole steering and tested all the cables in the SRS system. After hours of checking, he finally found out that one of thec cable connector to the airbag (round black thing behind my steering, i dunno wat is it called but the guy told me that the thing is the mechanism that makes the whole SRS work. He told me it will cost rm400-500 for a brand new one. The airbag another few hundreds more.), have broken. All he have done is pateri balik the cable, did some cables tidying up underneath my steering (all the cables are in mess, as i think the factory just pushed all the cables in and screwed up my steering thus resulting the problem. Should have taken some pics but my k700i no battery and takada bring camera). The price for fixing it? RM100 for everything....Price might be slightly high but the effort given by the guy was good. At least he took time to check out the actual problem. I think if send to service center, sure they will tell me that my SRS "died" adi and need replacement.
