Oderf said:mie, ur car is too fast people dun want to believe its only 1.6 ler.....ahahahhaaa......me either.....ahahahahaaa...
aiyoo... mana da laju bang....
its standard 1.6 oni.... view to believe... kekeekeke.. like motor add plak.. haha
hattech-v said:aiyoo... mana da laju bang....
V8_nutter said:Hattech,,im a regular at Nilai 3,,,didnt recognize your car,,,what chassis are you using ? which team,,,? din, bunga, wan konggo ?
hattech-v said:the engine just being overhauled...
this is the setup
b18cr block - change the piston ring n some cleaning job to make it shiny.. haha
b18cr head year 2000 - new head gasket
b16a eg intake manifold with b16a injector
p30 ecu with mugen chip
before the engine kaboom, owner did retard the base ignition timing fr 16 to 15 due to knocking at low rpm...
J101 said:knocking at low rpm. thats a start for your investigation.
maybe it was lean, lack of fuel. cylinder overcooked and cracked.
mugen chip are overfueled chip but only at high rpms.
just my 2 cents.
running rich is better than lean...rich at least contributes cooling...hattech-v said:i wonder the same thing oso...
the day before then engine got blown i asked the owner to check the afr.. but he refuse..
this is the setup
hattech-v said:btw, u fr which team?
n what car ?
poji_EG9 said:My answer, engine setup (b18cr) not suitable with that mugen chip P30 which previously for b16a setup right?.....
Mean engine running with wrong A/F ratio...different compression ratio (CR)summore.....
