[DIY] Oil catch tank
See that round flat thingy on top of the left bank? It functions just like an oil catch tank...difference being the oil is then fed back to the engine instead of being burnt off or thrown away like aftermarket oil catch tank.
Which picture? Would like to discuss this if you don't mind
D7zul
2,697
848
Shah Alam
if it's from the factory, of coz they can produce an oil catch tank & feed back the oil to the engine..
to feed back the oil u need a 'hole' in the engine & i think none of us can DIY that..
:biggrin:
feipepe
293
13
balakong
hi bro zul,
can u tries to upload overall picture the hose connection from oil catch tank to engine head. because i also wanna to install this oil catch tank on my silvertop engine. :driver::biggrin:
D7zul
2,697
848
Shah Alam
hi bro zul,
i think this picture would be easier to understand bcoz my engine have a hydrogen generator :biggrin:
put the oil catch tank between the yellow lines..
feipepe
293
13
balakong
hi bro,
what is u meant that hydrogen generator. it seem like the new item i never heard it before. can u clarify the function and also the feature a bit . quick interest of the phrase word hydrogen generator.
feipepe
293
13
balakong
hi bro zul,
i still quick not understand well regard this hose section i had draw in red colour.(please refer to attached photo. based on this pic, that hosing will be connect to where? :confused:
D7zul
2,697
848
Shah Alam
i'm not trying to promote or anything.. but..
the hydrogen generator i bought is called E-gas..
it produce Hydrogen Sulfide, Methane, Oxygen & Carbon Monoxide.. checked with a gas detector..
the 1st 2 gasses is flammable, thus contribute to better combustion in the engine..
it doesn't drain the batery coz it only uses 1amp.. checked with amp meter
after i install it, feels like an increase by 5-10% power.. roughly.. not much.. but ok la..
the only downside of the thing is it needs to be cleaned every 3 months or so..
recommended to people who opens their hood every now & then..
not recommended to lazy people :rofl:
:biggrin:
---------- Post added at 05:51 PM ---------- 6 hour anti-bump limit - Previous post was at 05:50 PM ----------
hi bro zul,
oh.. that's my hydrogen generator hose.. here's a few more picture
:biggrin:
feipepe
293
13
balakong
:biggrin:
:biggrin:
hi bro zul,
i have doubt regard ur setting hydrogen generator.as u mentioned downside thing, what is the downside connection? is that filter part inside the generator tank need to clean? and also this liquid hydrogen will flow through to which part? or connect to fuel pump?quick interested with that setting. can u share with us?:proud::driver:
D7zul
2,697
848
Shah Alam
hi bro zul,
the hydrogen is actually a 'gas'.. not liquid..
the hydrogen generator is actually an electrolysis device that separates hydrogen & oxygen from H2O (water) just like what we learn in school..
the gasses produce is connected to intake hose as u can see in the previous pictures.. there's nothing under the orange thingy..
u can find it at mudah.my .. there's where i buy it too & it cost rm450..
actually, u can DIY the thing.. but i'm too lazy to do that :rofl::rofl::rofl:
below is the diagram of the hydrogen generator..
---------- Post added at 01:55 PM ---------- 6 hour anti-bump limit - Previous post was at 01:49 PM ----------
u can read more info in this thread...
http://www.zerotohundred.com/newfor...iy-the-probably-the-only-real-fuel-saver.html
Gudluck :burnout:
feipepe
293
13
balakong
hi bro zul,
i had been finish install based on ur information given. please make a comment with it:biggrin::biggrin::biggrin::biggrin:
Dear all sifu,....
i had few question to ask...
My project are bot on turbo to 4g93 sohc engine...
I had whole set turbo kit wif 390cc...
And it was low compression piston already...
My question are....
Can my original 4g93 sohc ecu and air fuel change to 4g63 ecu and air fuel?
Witout change wiring... I mean juz plug and play ecu and air fuel...
Or changing it to gsr ecu and air fuel... Witouut wiring?
Coz i dunwan buy piggyback...
Beside...i can get ecu and airfuel...
