thanks for ur pic.....the hose just leave there?? no need to hold/connect to air filter?? safe ar??Originally posted by servo@Nov 26 2004, 15:24
some sample..CAI widely use even for Nissan Micra K11 fan...carbie engines
What's the different between this setting with a drop-in??Originally posted by servo@Nov 26 2004, 15:25
schematic...diagram ??
minimum also 2 ft any sizeOriginally posted by ksgoh@Nov 25 2004, 21:11
ninja, how much have to purchase (minimum)?
your's EFI??...well actually stock air box system is still restrictive..due to condition inside the air box it self...wat u can is....making the air entrance more bigger..let say 3" or more..grind the inside surface to be smooth(usually it rough and got some 'kotak-kotak' ones)...... :DOriginally posted by ]\[ickless@Nov 26 2004, 19:39
Emm.. if so, i got a K&N drop-in air filter install inside my stock system. How much different in term of performance, my car would gain?
Jez a silly question ler, but i need to know if izit worth to do CAI on my stocks.. ;)
yepp.. maybe ur right. i just thought the water vapor might actually cause future problem.. anyways, thanks for the feedback man.Originally posted by tykoh@Nov 26 2004, 13:55
i belive before the water condensed to water droplets it already vaporize because of engine heat.... dont forget your engine is not running in cold....
