dashboard n engine
henter
hey im bit complicated....now im using 1.5i saga standard engine..then i want to change the engine to use 1.5 dohc mitsubishi is it right the we need to change the dash board because some of my fren said carburetor engine n injection cant use the same speedo meter.....is it we can still use the saga dashboard.....after all i cahnge the injection engine....want thing is it using injection better consumtion than carburetor?
ooooo.......like that its make worried to change engine.......so itsstillcan using saga dashboard rite?
you will not get JPJ approval since 1.5 DOHC require engine mounting modification.
If you really wanna try your luck, what i heard from some member is you go to outstation JPJ e.g Kedah then possible to get register. KL/Selangor even you give undertable $$ also cannot get it done ler....
Good luck !
I think the different between injection and cab engine speedometer is :
injection speedometer have check engine light, however cab do not have. So, cab speedometer cannot use on injection engine.:X-:
