Convert EF Carb to D16 series engine
normality78
3,052
23
5,138
JB
Guy's,
Hope some sifu can enlighten me. Basically, how much does it cost to convert Civic EF ori carb engine to D16Z engine? From what i found out, the gearbox mount need to be mod. What others stuff need to be mod? Can i use hydraulic gearbox that come with stock d16z eg? much appriciate help
LuKa
618
19
Kedah
the other problem is to fit the meter in the ef dash... other options is to rebore ur ori block n fit in the 1.6 piston... g,box use the ef g.box so u dont need to modify the mounting bracket.. the rest the top part of the engine... head wiring n meter uses the efi ones... but u still run on cable clutch
normality78
3,052
23
5,138
JB
how much will it set back if i were to do so?
LuKa
618
19
Kedah
depends on ur option... if you decide to retain the EF block n retain the Ef g.box, it should be the cheapest option... u only need to change the top part including wiring com.box n meter... if rebore for 1.6 piston should incur more expenses.. when u dismantle the engine usually wear parts like Mounting is needed change+lubricant oil n belt... so i say should be bout RM2-2.5K tops for this conversion... n you dont hv to endorse the engine since ur using ur ori block..
it also depends on which head you buy which determines the price and the performance... its either D15/D16 Non VTEC Efi Engine from eg models which is cheaper... or D15/D16 V.Tec Single cam models from Eg8 or Ek local models slightly expensive...
but for sure you will get better fuel consumption over carb
normality78
3,052
23
5,138
JB
tks for the reply bro. is the performance parts / spare parts for this model hard to come by?
LuKa
618
19
Kedah
performance parts for D Series engine is minimal n rarely seen on shelf at shops... most ppl would opt for B series motor for further modifications since its a DOHC n hv more power..
only normal OEM maintenance parts are easy to source for D series engine and it is abundance at chopshops n sparepart shops and its cheaper too... some civics with D16Z Vtech single cam would opt for Bolt on Turbo rather spending RM8-10k for B series convertion...
normality78
3,052
23
5,138
JB
tat is what im trying to achieve. D16Z turbo. Maybe u should start to source frm US site as i think they got more parts over there
civic_mind3d
13
Just wondering for carburator to injection conversion, for sure we need to change the fuel tank as well.
In this case if we take D16 from EG/EK, from which Honda model fuel tank is compatible with Ef 4 door? Is there a difference between 2dr/4dr EF injection tanks? Is EF9 tank compatible with the local model version of EX 4dr which is originally carburator?
LuKa
618
19
Kedah
What du u mean i source? if i were doing this convertion it would not be cost effective to import parts from the states...
yes.. the tank hv to be replace... im not sure.. but i think ef models will fit nicely ef9/ef8... other options is installing a fuel pump
normality78
3,052
23
5,138
JB
ops sorry. typo. I mean i source.
devilz 78
376
9
kuala lumpur
it can be done, most parts are cheap too, u need a full set of intake manifolds, injection wiring set with ecu and fuse box, and some minor stuff like fuel pump, fuel tank and fuel filter pm me for more info:nurse:
Where do you go in Singapore to pimp your ride? Are there any clubs/groups/showcases of people that have pimped their ride?
