Clutch difference
You could try the EK9 clutch set as you use it for the daily grind to work. It grips better than the stock B16A ones as there is a diference in pressure plate size. The stock B16A pressure plates should be around 8.3 inches in diameter whereas the EK9 pressure plate is 9 inches in diameter. Thus the gripping would be must better than the stock but slightly below the exedy 3 puck ones.
I have just only changed my exedy clutch set to the Ek9 ones, wanted to go back for the exedys but the thought of really fast wearing on those exedy's made me change my mind and I decided to try out the EK9 clutch set. And yes, the feel would be "lighter" if compared with the exedy ones.
Just my 2 cents.
oh, btw the EK9 clutch set can be bought for about RM750.
Just my 2 cents.
