Skywalker, since its quite difficult to get weber carb nowadays , will proton 12v carby do the same job? (in terms of power). I've heard its using same principal as SU carbs. They r selling at rm1100-00 for OE units and RM600-00 for china ones. Chop shop selling rm450-00 .
Any comments?
yeap.... definitely....
the advantage of weber carbs is its tunability... ability to swap jettings and venturies to suit ur engine setting.... besides, most single weber carburetors has dual barrel... either open simultaneously (dcnf) or progressively (dgv).... why dual barrel is better than single barrel, i have to read up again... more or less same concept as 12v or 8v cylinder head engine....
standard aisan carb (proton 12v carb) has fixed jettings and choke... what normal mechanic do it jz adjust the air/fuel ratio.... what more extreme/expert mechanics do is they dismantle the whole carburetor, locate the air and fuel jetting, remove and cut/sharpen/mod the needle valve to be bigger according to ur engine settings.... this is a one-way-mod.... hence not many mechanics dare or able to do it.... once ur setting ruin, u need to find new carburetor adi....
