Brake change or upgrade?
Acer1810
Jul 29, 2014
6
503
Dear all,
My sis owns a civic fd2 and frequently require a brake pad change.
Which would be better?
Option 1: A brake calliper change with skimmed rotors or
Option 2: an entirely new aftermarket brakes with rotors?
If there's any other options do suggest.
Thanks!
All depends on your budget.
Got the money? Aftermarket new everything.
Don't got the money, skim and change pads.
But will after markets brakes last longer?? I suspect that it's a design issue or sheer bad luck?
Last longer? How much longer do you want it to last? Hard pads that supposedly last longer will probably have poor bite or require heat to work properly (high temp pads). Both dangerous.
If there's nothing wrong with your brakes in terms of bite, effectiveness, then don't worry so much about it la. Worst comes to worse, try a different brake pad brand like Ultrex or Ferodo. Or if you have the budget EBC or Mu pads or something.
Oh btw, how do you know it requires frequent changing? Mechanic or you brake until there's a screeching sound?
mADmAN
1,840
547
and how frequent is frequent?
tell her to engage into N if the car is stationary for more than 15 secs.
girls tend to just step on the brake pedal when the gear is in D.
Car Stationary, where got wear the brake even though step on it. I think since auto, the sister use the brakes a lot....:biggrin:
Stephen1978
11
1,503
Hi there,
I'm driving a civic 2.0 as well.... Faced same issue. I've solved this issue by changing to Endless brake pads (type SSS)- front only suffice and used Endless brake fluid...
Currently in my 3rd set. No complain. Be careful when considering aftermarket calipers as we need to ensure our spare tire can still fit into our car since our spare is not the full size tire.
Hope this helps...
gunnerzz
Jul 3, 2014
2,109
695
Melaka
Even aggressive driving with stock pad wont require frequent change.
Then again "frequent" is not an accurate measurement.
Automatic car will have the pad worn out quicker.
What is suspect is your sis is riding the brake which is not a good practice esp going downhill.
The best thing to do which is the hardest to do is to get her to change her driving style.
The easiest thing to do is to get a better pad. Do note that some aftermarket pad are design for specific usage such as street and track with different optimum operating temperature.
Choosing the wrong pad might result in she complaining more.
U dont need a new caliper, not even a new rotor unless the current rotor is too thin.
Its not like she is going for track session.
es2611
951
175
u can denote the "frequency" by mileage travelled. my Endless SSS lasted about 45k km.
i rarely clocked 45k km a year thus changing pads are 1-1/2 yr maintenance.
Mine last about 3 to 4 years. Now 14 years on my 4th set of pads only....:biggrin:
what is considered a senior member by zth standard is, 50 posts minimum and 5 years on the forum. lol! so ive already achieved it
put it in this scenario. if a solider is granted corporal in 2003 and this guy is granted corporal in 2005. both of them are corporal regardless, senority would still be the same! LOL
no la, i had promoted many people. those other peeps i have been asking didnt sounded positive!!! sadly, but i know u are a good friend!! just one day we have to sit down and...
