BMW comes clean on the 1 Series M Coupe
Dinesh
http://www.zerotohundred.com/?attachment_id=16729
The tease has been agonising, to say the least, but BMW have finally released the official details on their new 1 Series M Coupe after tormenting us with the trickle of information they kept releasing to whet our appetites without actually giving away much.
http://www.zerotohundred.com/?attachment_id=16730
It has been known though that motivation will come from the twin-turboed 3-liter straight six, the only blank spot being how motivating will it be. Well, official figures rate it at 335hp along with 450Nm of torque. Early rumours had estimated power as high as 350hp but the current figures leave it identical to the Z4sDrive35is that shares the same engine.
http://www.zerotohundred.com/?attachment_id=16735
To make things a bit more interesting though, there’s an overboost function that pumps out an additional 50Nm of torque if you require so. Performance figures see it breaching the century mark in 4.7-seconds while top speed has been electronically limited to just 250km/h.
http://www.zerotohundred.com/?attachment_id=16733
Fortunately, all that power will reach the rear wheels through a proper six-speed manual transmission, the only option available on the order sheet. Nonetheless, the rumours have indicated that a dual-clutch gearbox might find its way under in the future.
http://www.zerotohundred.com/?attachment_id=16736
In true M tradition, the 1M features an M Drive button on the steering wheel that improves throttle response but doesn’t seem to bump up power. Furthermore, there’s an M Dynamic Mode button to allow more leeway before the electronic nannies kick in when things are on the limit.
http://www.zerotohundred.com/?attachment_id=16731
Compared to its 135i brother, the 1M has had its front and rear tracks increased by 2.8-inches and 1.8-inches respectively. Weighing in at 1,495kg, about 35kg has been shaved off compared to the 135i. Filling out all four corners are M-specific 19-inch wheels wrapped in massive 245/35 rubbers at the front and wider 265/35 rollers at the aft.
http://www.zerotohundred.com/?attachment_id=16732
It’ll be interesting to see how the 1M fares. BMW themselves are comparing it to their purest model yet, the E30 M3, and in comparison to its modern counterparts under current circumstances, it does tick all the right boxes. Still, the question remains, is it enough?
http://www.zerotohundred.com/?attachment_id=16734
Source: BMW and Autoblog
in all honesty,d side profile looks very much like a modified Saga BLM,hehehehhehe
IMO the wheels are just too big and out of proportion with the body size. The ground clearance becomes too high especially at the rear. It would look much better with 18 or even 17 inch wheels, and that should make it even faster. Seems like a great car nonetheless.
Yeah 18" with slightly narrower tires would be just nice for the car. And it needs to be lower too.
