Black Top 20v - No cold start
lcmg
Hi all,
I just transplant 4age BT to my seg. Tested the car, everything is fine except it didnt cold start. when i start the car in the morning or when its cold, the idle is at 800rpm and it stays there, it does not go up to 1.2k rpm and comes back down like normal.
What is wrong with the engine? Please help, thanks.
Hi all,
I suspect is Auto Clog is not plug in, or already faulty.
check engine light is not on. what is a auto clog? where is this?
i think his talking about the ICSV (idle control selenoid valve) which literally control the idling...if it already kong...CEL will light up...but that thing can clog and make your engine idle like s**t...
for me it is weird since it idle too low...my ICSV already kong when i finished my transplant...during cold start my engine shot up to 2k rpm and stay there...but never encounter such low rpm cold start...
I not sure what it call, but i call it auto clog. There have 2 vacuum hose plug it in, and inside that vacuum hose got water 1... Normally can see it connect to throttle body 1...
besides this problem, Rpm is slow to climb when i step on the accelerator fully.i feel that the engine has sluggish responds below 3k rpm even on 1st gear (feels like something is holding it back) but after 3k it is smooth and responsive . Is this normal for 4AGE BT engine? if not, what is wrong?
You could always send your car to another 4age mechanic to diagnose. After I transplanted mine I had the same problem, no cold start then I send to another 4age mechanic, he said a few vaccuum hoses not connected, even the power steering is not compensated (rpm will auto adjust when u turn steering during idle)
