my engine is now running without the thermostat. and my radiator fan is connected to the 'on' in the ignition switch. tat means once the key is turned to on, the fan starts working.
effect: idling damn 9 high, water temp damn 9 low.
a mech told me tht i must install a thermostat. or else the engine will be always in 'starting condition'. just like whn u start the engine early in the morning. too cold, then afr will be richer. whn rev up, the rich afr will kill the engine...
abt idling higher i noe lah, engine warm up needs more time. but abt afr richer...how true it is?
whn engine cold, idling high is because of the idling control valve rite...
only letting more air into the combustion chamber...not pumping more fuel rite?
so how can this affect the AFR?
or maybe in cold condition, the engine will pump more fuel, decreasing AFR. then O2 sensor will not compenstate to reduce fuel coz engine cold even if the afr is rich?
Here are some Evo X that i snap back from Super import nights... :-Chua :stupid::ciao:
