AYC oil
lancer_ajai2
Kuching, Sarawak
Hi,
Just wondering is there any other type of oil thats suitable to use with the AYC diffs?According to the manual its supposed to use Diaqueen Super AYC Oil, but i've search all over my hometown still cannot find.
Btw, for the reservoir inside the boot(for the ayc), we're supposed to use Diaqueen ATF SPII right?
Thanks
bro's... dun play play..the AYC fluid very important. This is special oil for the AYC gear box n the oil must be change every 5000km. last time when i just bought my EVO4, That guy never change the AYC oil so u speed on the corner then u'll hear the sound like grak grak......after change the oil then my car ok liao(can go high speed when corner no more sound).
Remember my advice....if u dun listen to me then ur car........??? INGAT if u cannot get he oil then pm me , i'll let u know where to get...
Bro, thanks for the advice. But ur sure its 5000km change? Someone told me once its a 15000 km change once. I'm not doubting you, just really want to know. I'm new to evo ownership, so need to learn from u guys. Btw, where can i get that AYC oil?
wow... dis ayc oil is expensive right? then one of the first thing i'll have to do dis friday after picking up my car is to check dis ayc oil...? and also motor oil...
Hope the experts can advice me on this. Cause tomorrow my mech is opening up my AYC to replace a seal. If worst comes to worst i'd have to temporarily use back my used AYC oil.
any ATF SPIII will do. its better get the genuine oil from mitsubishi.
u can try to ask your local spare parts shop, i am sure they have. the mit ATF SPIII used as proton gear oil.
I do it 15,000 to 20,000 interval, also depends on how hard u drive.
It cost rm130 per/can. You will need 1 and 1/2 so basically you still need to buy 2 can. ha haa
normal service should be around 15K
check out n1 racing....i think they sell motul ayc oil for rm 55-60 a liter....
now ATF-SPII has been replace by ATF-SPIII....this is because they stated that the II is no more in production.....(in us/japan la)....
Shell got produced an ATF-IIIG....i wonder is it the same as ATF-SPIII???? anybody knows about rating ATF???
Just changed all the diffs oil, tranny just now. Am using penzoil gl-5 for the diffs and gl-4 for the tranny. Turns out the prev owner used auto trans fluid for the rear diffs, luckily didn't spoilt the diff itself. Anyway, after a bit of inquiring here and there in foreign forums, it is confirmed we can use the SP III for the ayc. In fact the manual for evo 7 & 8 states to use Diaqueen ATF SP III for the AYC. Here its selling 100+ for 4 litres. Which i think is reasonable. Btw, have any of u guys used Wurth engine oil?
hye there..if for ayc oil evo4 need how much littre?? huhu im new here in evos
p3jal,
Technically it required 1L, but you need extra for bleeding process.
To be at the safe side, prepare 2L.
Hi guys..
yesterday i buy AYC oil (Dia queen) from ah kit..
just call him at 0126107616.
