Any remarks on td05 18g
marlinished
I was told recently that there are some problems with the td05 20g highbrid, so now only available td05 18g, any comments/using. Looking at doing this upgrade.
BTW what should my min size injector be for this upgarde?
18g, got a evo2 a fren running on it, 510cc injectors 1.4bar , microtech
remember its tuning thts important after u change ur turbine
I planning to upgrade the injectors, then upgrade the turbo. Still prefer getting a td05 20g, any suggestions to get this cos i'm sure the 18g will be less hp than the 20g.
if u berani then u can do like mine la
T04E garrett housing ,
CHRA is td05 , rear housing is 7cm evo3
housing is similar size to a td06 , fin size equivalent with 20g fin.
rated around 650cfm in dsm sites
summore u will be able to use back ur stock manifold
t04b housing will also be good
but remind u tht i run a vr4 block not a evo1
and i dont run a stock ecu
wht u need to do to run with a bigger turbine
injector 550cc , bigger fuel pump suggesting a walbro 255lph
sard regulator ( u need it ).
retune atleast a E-Manage or Drax Ecu Chip or Matspeed tuned chip
safc2 wont be able to tune ur ignition at all
metal gasket recommended 1.5mm MMC thts the cheapest, u can go for toda , power n hks
intercooler hoses , the getah one wont be able to told more than 1bar safely , summore u r increasing ur CFM
if u want to know more about td05 20g , ask Khoyos, he is running on with drax chip , hehehe, bt 550cc rx7 injector.
wah jin.. turun ilmu hehe.......downloaderd knowladge.. hehe.. jinkl setup is good..
flush : hheheheh it was pretty cheap
i paid 1.3k for t04e polished housing , t04e fin , reservice the turbo using td05/06 kit.
waahh jinkl ... where u sent to do all those? looks pretty cheap
Ya where did u do it, sounds like a good deal. So its basically a td06 20g.
Heard that walbro pumps are noisy? sard and power better?
building a beast, got sound sure laaaaa :P walbro sound like a song, hahahahha
marlinished, u got pm
khoyos : u the king la man :D
any idea on the TD06-19C turbo? is this turbo better than TD05H 16G or 18G?
any experience running the td05/t04 hybrid on a gsr?would it cost so much lag?thxx
evo killer = khoyos
skyline killer = flush
fighter jet killer = jinkl
MUAHAHHAHAHAHHAHAHHAHAHAHAHAHAHAHAHAHAHHAHAHAHAHAHHHAHAhh.....
wow pretty cheap for the whole housing....nicely done up...planning for future upgrade too...currently running on td05 16g but fully rebuilt by blitz garage...lets say if i were to change my turbine as said above do i need to get a stand alone or i can just use back my e manage?thanks for the info guys..
yeah walbro sound sweet....haha...especially at traffic light stops....ppl must be thinking wat is that sharp sound...haha..
if u r running a GSR engine , then 7cm turbine housing is ok
emanage is enuff, bt get bigger injector
if u run a 2.0 , recommended u take a full t3/t4 setup instead
Write your reply...
