AFR setting for B16A
ya lo.... how can it be possible ? i mean using fpr but still can get lean at low rpm and rich mixture at high rpm ? aiyyo..penin wooo....
or better dun use fpr n just set the vafc tu have lean and rich mixture combination throughout the rpm range ? ajar la sifu2 sekalian....
B16A Series
- Standard Pressure (with Vacuum Hose connected at Idle) = 30PSI
- Full Throttle =40PSI
Optimal setup for B16A with RON97 Fuel & Performance Mods
- Around 32 to 36PSI (With Vacuum Hose Connected at Idle)
But then each engine is different even if they belong to the same family, so testings & dyno is highly recommended
* 14PSI = 1BAR
*28PSI = 2BAR
Hope this helps.
Thanks bro, i've been running rich all this while then.... haiyyo... no wonder la fc so high... sigh...
if rich i wont be running on B16A la bro.... at least B18CR.... or maybe K20A... ada brani ? ha..ha..ha...
