adjustable..
luffey
helo to all zth members...i may not good about this adjustable and suspension ...can u all give me some tips on what type of adjustables shud i put into my 1.6 satria ..i think i want to put satria gti's one lor...can fit ah ?how will goes ?smooth or better balance while speeding? cuz my car now feels like to "gugur enjin" when it reach 160 km/h ..huhu..olredi put strut bar front and rear ..so hope u guys will help me sort diz things out.. :adore:
wun satria GTi absorber kaa???i hav one set front n rear....but...better u change to adjustable..better handling laa..cheapest is GAB..quite ok..but better is TEIN..best performance..but quite expensive laa..ur decision..but wut do u mean by "gugur enjin"????
can you explain in more detail which how it your "engine wanna drop off" feels like? didn't really get it. for which i know normal abs do tend to give you the float-y feel when your car reach 160 and above, because it's re-bounce rate wasn't design to work over standard specification of 140. and absorber will slowly loose it's bounce and re-bounce rating after period of usage. so a absorber change or re-work is in place. if you was "heavy footed" kind of driver which always keep your speedo well over 160, a decent set of performance coil-over is your choice over stock absorber.
bro,buy a TEin from chop shop lah,1 set about Rm1600.(like new one).GAB r cheaper but hear not so good response from user,very hard the spring,unless u get soft hard Hi Low adjustable one....
try to change out the bushes at all..front lower arm,steering rack bush etc,will make a big different.i using front lower Arm/rear lower arm. from EVO3,already change out the control feeling...try it..:wavey:
1.6 and 1.8 absorber is same 1, the different mayb is the spring rate only.. if u wan more to performance then get the adjustable. get the 1 from japan is more reliable than local 1...
R3 spring and absorber...new, can go for performance and comfortable... Some quote less comfort but for me it's still comfort. I myself use Tein Hilo Soft hard. Very good one, but for daily use i think it is unwise. You all know la, our country's road very bad. Just changed my front lower arm and tie rod end due to tough absorber and 'jalan teruk'... Huhu...
Hi,
just my personal though. I understand that adjustable absorbers can be service. but recently one of the workshop give me a tip on hi-low adjustable can be serviceable, not the hi lo soft hard.
can the guru's help me on this or suggest the shop that can do adjustable servicing..tq..
last time i called hotbits service centre, service range rm60-70 per abs.. hwl i dont knw.. maybe mr.chaiwl can provide some info here.. :biggrin:
izzit adj hotbits same with adj apm? coz i've seen them they quite similar...
maybe for certain model only?
go for titan if got the money...its tuneable...means they can tune wat u'd prefer yr ride to be...
track, super street or comfort...
if not can try hwl..not as stiff as gab..quality wise is still the same...price oso not so expensive...
if not can opt for zerone ...its hi-lo soft-hard... :biggrin:
Write your reply...
