About Absorber - Answer Needed
masvidal
Kota Kinabalu
hi everbody,
got this one silly question, can wira 1.5 use absorber for wira 1.8?
what different is there between 1.5 and 1.8 absorber?
im not kindda sure bout d front..some said can but some said cannot...
but d rear is for sure...CAN...
1.5 wira can use 1.8 wira's absorber.. front and back..
but cannot if other way round(except the back).. because 1.8 engine is heavier than 1.5.. so it's not suitable to use 1.5 wira front absorber on 1.8 wira
the rear.. no problem.. almost the same weight at the back
it's got nothing to do with brakes by the way
ok
Bro,
Wira i.5 if you want to use 1.6/1.8 absorber, for the front must use 1.6/1.8 springs and 1/6/1.8 top mount. 1.6/1.8 front springs bigger in diameter compared to 1.5 front springs.
For the rear ones no problem, Waja rear absorber also can fit to Wira 1.5.
RAD
019-370 1887
so meaning we can install 1.8 abs into 1.3/1.5 rite?...but have to modify it rite?...then,how bout da labour charges?how much ey?...coz im thinking of changing my current 1.3 abs to gti...
thanks for all the reply.
im asking this becoz my current absorber leaking already. im planning to upgrade to 1.8 absorber (kayaba RS).
this is also done bcoz by the end of this year, i will convert to vr4 engine.
so, can this 1.8 absorber withstand the vr4 engine?
and one more thing, 1.5 using 1.8 absorber is plug and play or not? no need modify anything?
if wan convert to vr4 engine..i think change to 1.8 KYB RS wasting ur money...coz at the time u change to VR4...u gotta change absorber set again.......1.8 cannot support
