A Simple Tutorial DIY Spray Project
wanna ask a question ... where u guyz get ur 2k paint can ?? i cant find any till now ...
broken sword,
u got dat right bro.. juz try then u'll know how it works.. i mean try on other stuff 1st..
XtasyM,
normal hardware stores got.. spray can types liao..
FoarGeez said:
Its juz called 'primer spray'.the usuall brands are Cap Matahari & Arrow Brand.. look for P/S Grey.. code number 5 :regular_smile: Its quite hard to find, but they sold this in hardware stores..
after doing some survey on this primer... here's my finding
1)DPI adhesion promoter 228's, all purpose flexible sealer RM 18.90... stated on the can that it's suitable for surface that paint alone hard to bond, for example plastic bumper, metal etc
2) Anchor spray, for undercoat p/s 5....RM 5 to 7
..... will update if find more:X-:
which of this one are best for plastic and dashboard surface and similiar to primer spray stated by FOARGEEz? can anyone help me...:emoticon_U:
good job:)
what car is that and how much u bought the lip? how much is the total cost for your DIY project?
bro where can get 2k colour spray? ACE shop will got?how much the price?
anyway...u handwork reali nice~!!!!
can be found in almost all hardware shops.. those rm5 per can. Brand such as Anchor,Arrow, Cap Matahari are among the popular being sold..
plan to DIY touch up my car paint. there is some deep scratch untill my car paint come out at the rear fender, can i just put the filling putty, let it dry, sand it, then spray the primer, let it dry, then spary the clear coat?
is it the normal can clear coat u using? i plan to spray on that particular part oni, will it look ugly? and after i spray, can i polish or wax it so that look nicer?
most errors are when spraying. yall should press the spray nozzle head maximum 1 second and let go. move in a left and right motion while pressing the nozzle and when an area is covered, move over to cover whole area. 2nd and 3rd coat, do the same if u wish to do so. then comes the clearcoat using the same technique. this way u dont get too much spray bleeding down and damaging the overall look.
u can buy the same color as ur car color through some hardware shop but small tin and expensive price, around rm15-18. i suggest u find a "steel paint" shop and ask for ur car color code and they will give it to u in the normal tin size (rm20-23)....
while ur there, get a rubber/foam waterproof sanding block for your sanding purposes. and the correct version of sanding paper is not those u get in a hardware shop but here. which is, 'kovac' eagle brand waterproof abrasive paper P80 for initial sanding and P320 for more fine sanding...
u can get the autocolor cement from a hardware shop. the real process is actually red color cement than yellowish-gray color cement (the steel paint shop mustve got this as well) and lastly "autocolor hard putty" for final coat.
when cementing, if say u doing ur mudguard, theres a lining usually on the metal (curves of the car/top half of the mudguard), if ur dents are below that curve, cover that up and cement the whole of the bottom half of the mudguard. this way, after sanding, u get the overall clean shave instead of tompok-tompok due to cover only the dents.
hmm... good luck!
:P
if so deep, ketuk first lar...
or not, after 2-3 month, or cement jatuh setompok kalau berat sangat....
no need ketuk bcoz it still in shape, oni the old pain is totally scratch out. can see a small part of the metal...will pay a visit to ACE hardware tml, and see if anyone there can help me out on telling me which one to buy. now problem is dunno what is my car color. and unable to locate my car color code also...normally where the car color code located ar?
either d driver door, the front hood or the manual. if ur car is proton/perodua, u can get like i said those oem spray-tin at ur nearest local hardware shop. but u can go to a "steel paint" shop and ask for ur car color, they will mix for u and put in tin straight away... kinda cool.... nearest steel paint to me is taman delima cheras, jalan 34/154. no:37. good luck! (just behind bandar tun hussien onn)
got the putty, the plastic scarb, the sand paper...tml will put on the putty and sand it...but i not yet get the primer and paint, i cant find the paint that look alike my car color. anyone noe where is the shop that selling variety of spray paint or any steel shop that can mix the paint around PJ area?i cant locate the color code also, door, hood...dun have, oni got my car model number and enginze code...:(...if let say i put the putty, sand it, then nvr paint it for sometime, ok ar?will the putty crack or some out if i dun paint it?
not really, itll stick.. put look not nice ler :P, whats ur car model and what color?
my car is nissan sentra N13 year 1988, color...i really no idea...i saw under the hood, stated color : trim color guranicion...i dunno what the hell is that mean. it look like dark green...metalic...or mayb dark jade for me...really headache dunno where to get the paint...haha...
this is my car, anyone noe this is what color ar?
http://img.photobucket.com/albums/v329/sky_lor/CIMG1784.jpg
Write your reply...
