hi,
i'm wondering if anybody here faces this problem, currently water is leaking in thru the door's window le.. i'm driving a SO4 sedan, that makes it 4 doors and noticed the water leaking in thru the rubber mouldings (not blocking the water from entering the door).. so when you open the door, you will notice water leaking out thru the metal.. and even dripping sounds :(
i open up the side-panels and noticed the paint inside has bubbled up too..
any ideas how do i go about fixing it? Since this is a 97 model, i'm wondering if there are other causes to this.. especially if changing the rubber mouldings still doesn't get the problem settled..
btw, how much does the rubber moulding costs?
