bro,did u sloved ur prob?
If the prob bout low rpm jerk higher rpm no jerk it's better now, if I drive fast, change gear fast, no prob, if I change slow abit then it will jerk, down shifting from 5th to 4th then 3rd, sumtimes it will jerk while other times no prob. Still tryin to find out what's the prob. It's getting better while I drive more often so hopefully I just need to run in more ?
---------- Post added at 04:38 PM ---------- 6 hour anti-bump limit - Previous post was at 04:35 PM ----------
like i said, ive experienced both; slipping and not slipping after changing the clutch. the worse was when there was a leaking from the gearbox oil seal, and the revv went through the roof when power is applied. the clutch plate was wet kaw2 soaked in gear fluid, dat was not fun langsung
Well my case no slip or anything, just when press clutch, let go, will feel abit jerk, i'm tryin to compare quick shift vs slow shift, and it seems if I let go my clutch fast no jerk, if I let go slowly jerk.
If rev and change gear quickly then it's very smooth, it only occur when I rev and change gear like ah pek, it will jerk. Quite funny actually, the more I try to make the gear change smoother, the worst it will become, the more rough I drive the better it seems. :rolleyes:
Anyone interested ..... CT9A model
