20V wiring help.......
yeeza
67
7
508
last 2 weeks my car suddenly overheat then one fuse burn...and whole car cant start then got to know the faulty fuse...my mech replace the fuse and it last for 4days then my car overheat and cant start..same problem but this time i change it myself but only for few days it started to burn again ..so i go back to the mech and he replace it with a bigger amp fuse which i scare will burn the whole car if the wiring or what other problem being check properly ...any sifu to recommend ? ampang/cheras area
yeeza
67
7
508
my 1 20a fuse support my fan+headlight...all this fuse burn started after i added an earth cable from body to engine ..
yeeza
67
7
508
i just take out the earth cable and revert back to ori 20a fuse ...see few days got burn or not ...for your info my batt i put at back
-lanz-
147
10
Perak/Kedah
Might be some problem with your fan or grounding wiring.Why do you put your batt at the back?
Hi, I would like to know where there any solution for my car with problem at below:
Proton Wira 1.5 Auto 1999
The issue I having here is the car can't start. The car drive for 5min, stop the car (around 5min) then the car can't be started. Then need to wait for 10 to 20min lets the engine cool down, the car will start again, once the car start, the car can drive smoothly without any issue. Only when stop for petrol the issue come again. Already try 3 mechanic, the problem still...
