front drive grip???
the best chamber for daily front tyre -1.0 enuf..
even during tarmac rally i only adjust -1.5 la....donwan to looks like too much like touring car close to -3.0 degree oso have....
front anti rollbar need bigger...19-21mm would be good...but u'll felt your current suspension setup becomes harder than usual...
SE86
299
474
1,563
sure need to scarifice comfort for performance..
karl_razlie
514
56
5,028
Puchong
put LSD...if u proton, perodua or daihatsu can ask powerzone to put custom LSD for ur car...price around RM5++....
Zeroed
1,705
45
Just my humble 2 sen...
You have to know what you want and ask properly... What do you mean by front drive grip?
You want your car to handle better in the corners, or you just want more grip at straight road/launching? Or more traction while accelerating out of corners? All the suggestions everyone posted here are for different things... if you do some self study and ask around with the correct questions, you are more likely to get what you want without wasting money on wrong modifications.
If you just want more grip, 80% of it depends on the tire. Buy good tires, then got good grip. Suspension kong kiau also got grip. The wider the tires, the more grip (Rim size doesnt matter, a 225/50/15 will have more grip than a 195/45/17. However, the lower the tire profile, the more control (less sidewall flex), but the less comfortable).
If you want good handling and traction, now thats a whole different story.
Just to correct a few things here, stiff suspension, thicker anti-roll bars, etc do *not* give more grip.
If you only install a thicker anti-roll bar /stiffer suspension in the front without changing anything else, your car will actually understeer more. You need to increase stiffness in front and at the back accordingly to get good handling. You will get less body roll, more car control, but this doesnt necessarily mean more grip.
If you add camber (not chamber, guys...), it will give you more contact patch when your tire flexes at cornering, hence more grip in the corners. But when on straight roads, you get less grip than having a straight camber.
LSD increases traction, but does not increase any physical grip. Traction = your car's ability to sustain grip on 4 wheels as a whole. Basically, people tune the car to maximize traction, with whatever grip that is given by the tires.
karl_razlie
514
56
5,028
Puchong
go for LSD hehehe..with LSD and without LSD i feel much different...but stereng a bit heavy la when cornering....traction superb..
Che.Det
124
u already answer it all, thnxx
Hi there,
I wonder is proton 4G92P and 4G93P thermostat is the same?
I'm wanted to change my thermostat but not sure which one?
My current engine heat level is just above 2bar where my friends all
is above 3 or 4bar or half?
please advise?
