- Joined
- Jun 4, 2008
- Messages
- 30
- Points
- 1,506
Re: integra Headcounts!!
Thanks a lot for everyone about sharing..........
About brake pump upgrade,i think should be whole set gua...picture below;
Yup,may be EBC brake pad is my next step to upgrade,or may be change to steel brake hose 1st...Actually,i'am depend the bugdet 1st,if BB1 braking system not so much expensive,may be will direct upgrade it...
Yup,i agree what u mean...Braking system and stabilizer system more important for me compare with performance...Because i know my life no take two...hehehe
About "warped",i really not sure...But,when i brake that time have some sound...This sound start come out after i changed the rear brake pad(honda ori) and "skim" the disc...The technical say is honda brake pad problem,somemore,this brake pad cant be claim...I direct @#$%^&*@#$%^& that technical...i'am no choice right now,just continue using it...Am not sure wat cambers are mine lar....but mine not too low....
Warped means the brake disc "bengkok" not smooth anymore.... when u brake does it have any sound? if yes then its warped......
U changed the brake pump but did u change the brake servo? I suggest u change to the type R double layer one....it did make a lot of difference for me.....but again if u really want more porwerful braking u should also consider the Prelude BB1 disc and caliper....much larger and better grip.....
MK pads am not sure....usually I recommend EBC....or if u use the Prelude disc and calipers u can try Endless.....
What you mean "cheap pad wont bite ur disc n makan ur disc"????cheap pads wont bite ur disc n makan ur disc...
u guys can spent ribu2 lemon on engine, cosmetic like ah beng with spoiler sidai kainbut some fellows i dont understand... braking is the 1st priority n most important thing u do
I am totally agreed with u Rin, BRAKING SYSTEM is the most important part; the moment i bought my DC last time, the next day i change the braking system to Honda others car bigger Disc+Caliber, Disc is Dia=12", Cal is 2 Bot., bro, don't compromise this conversion with other not necessary spending..![]()
