dont care bout him le...he hate proton one...whats with the LOL bro??
anything wrong being a protonhead?
i found 1 owner who turbocharged his campro on pesona..Any campro with BOT owner here?
woah.. its already too much power for campro engine.. :proud:theres lots of BOT campro around, and campro definately do have lots of potential. However, do remember to stay with moderate boost unless you have your internals done up nicely. With everything stock, its not recommended to go above 0.4 bars of boost. Boost higher once you have replaced your pistons/conrods, headgasket etc etc.
On average, most BOT campro with 0.4bar could achieve approx 160-170hp on wheels.
yes, poor taste
well maybe you will face knocking problem, if u can lower the compression ratio at least to 10:1 or less then it should be ok to raised the boost may be up to 0.7 barit seams right, coz it's internal parts not design for turbo usage, so it just can handle boost 0.4bar only... but that only produce 160-170hp, quite impressive n remarkable result coz just 0.4bar boost only...
keep the modification spirit goes on...
