4g91 gb should be sufficient .. but if u have xtra budget ... mivec gb is the way to go!
Fren...don't be insane...yes i know that mivec gb lsd is quite expensive coz is "barang baik" n for performance..hehe..my budget is less 2k la complete with cluth,flywheel,etc n installation..what about the price of non lsd-mivec gearbox? what is the advantage n disadvantage using lsd?if my batery "kong" i heard that is hard n heavy to "tolak" the car if gearbox have lsd..hehe..is it true?![]()
It's same...u r using 8.5' flywheel...how u expect ur car can start by push!?!? Or u can do it now?
Trust me...my exp. on semi-race clucth not even can start after ur clucth pump spoil 'lan' joh!!!
the Fxxker stupid foreman masuk 1st gear & start engine...until now my gb sync gear damge liao...
Sugeest u buy jumper lah!!! Maintenance issue try not to bring into the mod. issue leh!!!
Hehe!!!
alapak..i think you miscall..eh wrong..hehe..misunderstanding my question lorr mr jack...i will not push n start my car la coz i still syg my gearbox la..huhu..my question are :
1. what is the advantage n disadvantage of using LSD(Limited Slid Diferential) Gearbox?
2. If your battey is "kong" n example for emergencies u want to push the car(for manual gearbox),is it heavy or can't push the car coz of the LSD in gearbox?..![]()
LSD is to allow both of ur wheel to move together...Fren...don't be insane...
Hehe!!!
But beware of the on wheel balancing...No!!! ur g/b will spoil!!!
LSD can help u in cornering...
the movement just like u won't drift out & will follow u desire handliing...
coz when corner + speeding, ur wheel will move imbalancely...one faster than the under press one...
so LSD could compensate each other so that cornering more smoother...
have u checked ur throttle body?Hi Sifus,
Got old saga year 1989 converted to 4G91 engine 'rojak' with 1.6 wiring. Pening kepala about the problem of my engine when turning air-con ON engine want to die..looks like RPM too low. Help me out to find me the modified mechanic for me to send my car repaired. Anybody knows who's who? Give me the address and phone no if possible.
Thanks
maybe kong...need to service but better change it!
