- Joined
- Jul 18, 2007
- Messages
- 733
- Points
- 1,528
Well, I have finally done my BOT and runned in. Now enjoying my ride... Touch wood, no coughing and no sneezing on my engine... Everything is fine boosting at 0.6-0.7 bars daily drive.
well, I've consulted one of my friend on the cooling system on the turbine.. One of my friend and I had an argument over a TD04L. Should it be oil cooled only or water and oil cooled... I insisted on water and oil cooled. And he keep saying that oil cool only is enough... and nobody oil + water cooled...
Well, I came from a mechanical engineering background and till now, I've been dealing with alot of machine built to produce heat... Well, I understand his message that says TD04L can be oil cooled only... But I couldn;t accept that he said no body water and oil cooled a TD04L and TD05... (Mitsu's OEM turbine)
If there is no purpose of having a double cooling system on a turbine, why the hell does Mitsu uses uncountable amount of effort and money in designing and producing a twin chamber cooling system.. I believe they don;t do things for no reason... And I also know that there are lotsa BOTs out there that only oil cooled the turbine... Can use I know can use.... But when say nobody uses water and oil cooled, I mean... i couldn;t accept lar...
however, this topic was brought to be compared with some of the garrett turbine that using oil cooled only.... Well, for me... It all depends on the initial designed cooling method... Well, Garrett using Oil cooled only because it's being designed to do this... So, the oil travelling chamber for cooling would be different from a water + oil cooled chambers... So, to my opinion, it's all about the design... Well, I know it's going to be a never ending argument if we continues... I ended the conversation with "nevermind lar... it's OK"
had a friend whom damaged his TD04L at 1 bar. Told me overheated and shaft bengkok. Send to Turbo Tong to repair cost alot, and finally got himself a TD04HL...
Met up with my cousin last week... Driving an Airtrek Turbo... Just upgraded to TD05. Wanted to sell his TD04L(Stock turbine) in very good condition. not even oil leaks and I asked him about his boost before upgraded to TD05. And I was suprised that he told me it's been 1.2 bars for 1 year + without giving any problem...
So... it immediately reminded me about the argument....
What do U think..?
bro if u study heat transfer then u now why sometime we need double cooling and some times just oil cooled..very simple..Bigger the area- heat can be transfer easily and also removed easily- concept 'extended surface'...smaller turbo usually need oil and water due to fact i stated above. engineer always calculated everything..position of the turbo also need to be consider..
garrett turbo- 'R' series which is ball bearing need water cooling system due to 'ballbearing' it self- to prevent it easily broken so need to reduce it working temperature...need more xplanation visit my workshop..bring semporna A menthol then i can story more- haha so lazy to write 'karangan panjang' here...
ps- shaft bend or cook usually cause by oil pressure not enough or delay- nothing to do with our discusion regarding cooling system
. price range could be few hudreds
