Hi sifu,
What causes a turbo to be blown-up, is it due to high boost or high flow?
Let's say, for example (only):-
a. The same turbo with 2.0L engine, boost at 14psi, air-flow = 28.5 lbs/min
b. The same turbo with 1.6L engine, boost at 14psi, air-flow = 22.8 lbs/min
Question:
The same turbo with 1.6L engine, boost at 21psi, air-flow = 28.3 lbs/min, will this turbo be blown-up [i.e. higher boost but the same flow rate]?
Question:
, even the GT Garrett series has its downs n ups , in US, the DSM ppl have already moved away from the GT series , due to price where they can get a much more reliable & serviceable Holset & Borgwarner for even less than 1/2 the price of the GT with equivalent flow and spool.
but cheaper then Garrett we called it Carrett,garmint and much more
