- Joined
- Feb 6, 2007
- Messages
- 587
- Points
- 1,516
Honda Civics are generally respected as reliable transportation, and aren't supposed to be prone to things like, say, wheels falling off. But that's the reason Honda is recalling more than 182,000 of them made in 2006-2007 (USA model).
Honda says the trouble comes from a leaky O-ring in the wheel speed sensor. Water could damage the wheel bearing, which could result in one of the four wheels falling off, "possibly resulting in a crash." Ya think?
Owners of the affected Civics can expect a note in the mail from Honda, offering to fix the problem and replace any damaged parts.
NHTSA CAMPAIGN ID Number : 07V399000
Mfr's Report Date : AUG 30, 2007
Component: WHEELS
Potential Number Of Units Affected : 182756
Summary:
ON CERTAIN VEHICLES, THE WHEEL SPEED SENSOR HOUSING USES AN O-RING SEAL TO PREVENT LEAKAGE TO OR FROM THE WHEEL BEARING. IF ASSEMBLED IMPROPERLY, THE O-RING MAY NOT SEAL PROPERLY ALLOWING WATER TO ENTER THE WHEEL BEARING AND EVENTUALLY CAUSE DAMAGE TO THE BEARING, ESPECIALLY IN AREAS WHERE USE OF ROAD SALT IS PREVALENT. IF THE DRIVER CONTINUES TO DRIVE WITH THIS CONDITION IT IS POSSIBLE FOR THE WHEEL BEARING TO BECOME LOOSE, WHICH COULD CAUSE THE BEARING TO FAIL.
Consequence:
THIS COULD CAUSE A WHEEL TO FALL OFF OF THE VEHICLE, POSSIBLY RESULTING IN A CRASH.
Remedy:
DEALERS WILL INSPECT THE REAR ABS SENSORS AND WHEEL BEARINGS FOR DAMAGED PARTS AND REPLACE THEM FREE OF CHARGE. THE RECALL IS EXPECTED TO BEGIN ON OR ABOUT SEPTEMBER 17, 2007. OWNERS MAY CONTACT HONDA AT 1-800-999-1009.
Notes:
HONDA RECALL NO. Q56. CUSTOMERS MAY ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION¿S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY 1-800-424-9153), OR GO TO HTTP://WWW.SAFERCAR.GOV.
Source:
http://detroitnews.com/apps/pbcs.dll/article?AID=/20070914/UPDATE/709140429/1148/AUTO01
Have replaced complete float unit (brand new from Wing Hin) still...
